Line Setting Ticket
rev03
Hey everyone. Great forum. There is a ton of excellent info here! Just a little background...just bought a '63 Scout 80 a few weeks ago. Finally got the motor pulled and am starting to tear it down. I recently received my LST which is very cool. I have been able to decipher most of the info, but had a couple questions I was wondering if someone could answer. First, any idea why there is no build or shipping dates listed on it? Wasn't sure if this is common. The chassis inspection card is signed and dated 6/18/63 so I'm confident it is in fact a 1963 model. My other question has to do with the last line that states "Prototype 4x4 #51." I've found a little info on this but I'm still not clear on what it means. So far I've determined that my 152 engine must have been switched out at some point bc the serial numbers don't match up, but no big deal. Also if you see anything else on the LST that jumps out at you please let me know!. Thank you all!
ihpartsjeff
Administrator & Owner
Staff member
Most of the LST's from around this era only had the dates on the second sheet as you've already posted. Yes it is a 1963 model year. The "Prototype 4x4 #51." was simply IH internal language to know that this was a common IH build using a certain set of standards. Otherwise nothing else stands out to me but I am not the best at reading these.
rev03
Sounds good Jeff. Thanks for the quick response. I look forward to researching the forum more and bringing this old girl back to life. This will be my first so I will be utilizing the great info found here. Thanks again.
