Mastiff
Re: The Lifter Thread
I think this is a good place to post this.
I'm rebuilding my 152 and I've never had any lifter issues with noise or anything, but since I had metal in my engine, and to be thorough, I thought I'd pull apart the lifters and make sure they are clean. I've been trying to follow the manual, but I find that the lifters are just totally solid and I can't compress them to remove the spring. I'm leaning my body weight into them and they won't budge. On one of them I popped the open end of the spring and then the piston moved up and pinched the closed end. I still can't even push that piston back to where it was. It's like they have a ton of pressure built up in them or something. Any thoughts? I wonder if this means the lifters are in good shape, or messed up somehow.
