jamesirwin248
I have a 73 Scout II with a 345. Im restoring it and I checked the transfer case for oil and it was near empty and I found the leak. I have a ramsey winch pto and the pin that shifts the the winch into gear is leaking. The pin slides in and out of the transfer case and the space around the pin is allowing fluid to seep out. I believe a bearing is the cause. What can I do? Or how can I press in a new bearing? I have a Dana 20t-case with a ramsey pto attachment
