IHCScout78
Hi,
I have a Scout II with a new brass brake proportioning valve installed about a year ago.
The valve is leaking from the front where the bleed button is under the rubber cap. There is a small spurt of brake fluid every time the pedal is pressed. It does not appear to continue leaking if you continue to press the brake pedal/maintain pressure.
Has anybody seen this? Is there an o ring or something in there that can be replaced?
