SSMinnow
77 Scout 345 FI'ed, tf727, d20.
I appears I am leaking from the bottom cover that covers the flex plate. I did take it to a shop and they suggested that it was the front pump and should be rebuilt. It looked like it was blowing back over the bottom of the pan.
I did drop it and did a reseal, replaced the shift lever, throttle lever, front pump seals and at the same time pulled the pump replacing the bushing, and put a new o ring on the filler tube. But it still leaks.
So is there any way to check to see if it's the tc or from the front pump? Nothing jumped out at me when I had the tc off.
