Key On Constant 12v Power Source
Hey gang. I am attempting to install a Holley Sniper system in my 76 Scout ii. I am almost done but need to connect one wire from the efi to a 12v power source that is key on with constant power even when cranking. I am useless when it comes to electrical. I know that when I put a 9v battery on my tongue it gives a good zing and that's the extent of my knowledge. Right now I am leaning to the positive side of my coil but don't want to fry the new Sniper unit. Thanks for any help.
Robert Kenney
Super Moderator
If you are certain there is not a resistance element in the positive coil circuit, you could use it. If there is a resistance element in that circuit, run a new wire from the same circuit feed at the ignition switch to the Holley unit and retain the positive coil circuit intact.
