I have tried.
Not a lot of responses. Which is ok
think maybe, hopefully, figured it out.
The 152 starts up just fine and runs fine untill I put it under load. It bogs down and has 0 power.
We are now thinking that the mechanical fuel pump does not have enough pressure and not getting enough fuel. When I pump the pedal, it starts to stall. Thinking of putting in an electric fuel pump.
Ive done everything else, timed, new plugs, new points, new coil, good compression, good oil pressure.
What do you think?
Thanks
