Installing Holley 2300
mbiver
Just got the new Holley 2300 P/N 0-7448 kit from IH Parts and had a couple installation questions. The kit came with the thick mounting gasket, and also a thin gasket (picture attached). I’m only supposed to use the thick gasket, correct? The thin one is just extra? Also, regarding the gold mounting studs, do I just finger tighten them to start and then the hold down nut fully tightens them when torqued? Thanks.
Robert Kenney
Super Moderator
yes on the thick gasket only. No sealant.
The studs should be screwed in ahead of time. Use two nuts threaded on the upper threaded end, tighten to each other and use the top nut to screw the stud in. Then remove the nuts.
I would use a little medium strength thread locker on the threads of the stud threaded into the manifold before installing the stud.
mbiver
Thanks, Robert Kenney. The 2 nut trick worked like a charm. Also took your advice on the thread locker. Got the carb mounted on the thick gasket only and hand tightened the nuts. Not too tight though since it only called for 60 inch pounds. Removed the EGR valve and covered with the nice IH plate in the kit. Moving on to the throttle linkage and wondering if anyone knows where all the parts go that came with the kit from Jeff and team? They included it so I assume I need it. Where do I mount the included summit return spring bracket and which hole on the linkage do I bolt the throttle to? If anyone has pictures of a finished/complete install on another Scout 2/345 engine I’d love to see it. Or if anyone has instructions that go along with these kits...anything helps. Thanks!
mbiver
Ok, so I saw a couple of super short videos online and kinda just winged it. I stuck a bolt in the hole up by the upper coolant return/thermostat housing, put the skinny spring inside the thick sprint and then hooked them to the bolt and throttle linkage on the carb. I then just attached the existing throttle cable to it as well. Not really sure what all the other parts in the kit are for so if anyone has more clear steps or a couple pictures of their setup I’d still be interested. Was I supposed to use the 2 springs, one inside the other? I saw one video online that had it that way, and one that didn’t. Regardless, I fired it up and she runs great. There was a stutter every couple revolutions and that has completely disappeared. And it will actually idle just fine at 500 rpms...crazy! I bumped it up to about 650 per the sticker on the valve cover. One interesting thing though. After I had run it for about 15 minutes then shut down for a bit, the next time I started it, some black soot came shooting out the tailpipe. Not sure what that’s all about. Was it just because it hasn’t run right in so long and now that it’s actually getting the proper fuel ratio it’s breaking some carbon loose? I don’t know. Anyway, thanks again and any insight welcome.
Looks good to me. Spring inside a spring hooked to a solid point directly ahead of the linkage. No tension when throttle is relaxed, tension when throttle is applied. The sooty discharge just looks like condensation mixed with carbon. It happens sometimes. Engine needs to be heated up and worked. Nothing to be concerned about unless you see black smoke and she smells too rich at the pipe all the time.
