IHCScout78
I put an aluminum intake on a 345 during a rebuild. 3 coats of permatex copper on a shim gasket, hylomar on the bolt threads, torqued to spec per pattern, at least for the bolts I could get a torque wrench on
it has developed a noticeable coolant leak on both sides of the throttle boddy. Coolant is pooling between the intake runners on top of the manifold. Bolts seem tight with a wrench; can't get in there with a torque wrench without some dissassembly.
I also have some coolant on the valley pan cover where the pvc oil normally puddles
I have never had a leaky intake manifold on the cast iron monster IH used before. Has anyone seen this on the aluminum intake?
