IH Serpentine Belt Set-up
ihpartsjeff
Administrator & Owner
Staff member
Started working ona serpentine belt set-up for the IH engine. First thing I did was have the crank dampner machined for a 6 groove serpentine belt. So far I have only installed the dampner and power steering mount. The power steering pulley is almost perfect. I'm waiting on both the alternator and a/c pulleys so I can mount those. The alternator should line right up. I'm already making a custom mount for the a/c compressor so that won't be a problem lining up that pulley.
SSV
Idler(s) or brackets (adjustment) for tension? Smog pump plans in the future? Thought: newer ac compressor/pulley off a vehicle that runs a serpentine belt already. Gotta check direction of rotation to find the right compressor tho'.
Looks, interesting. :gringrin:
:cool:
ihpartsjeff
Staff member
This one is somewhat custom to the application. No smog pump but will be using a sanden compressor. I got a little further yesterday. Ordered four idler pulleys that should be waiting for me at the local napa. I'm also waiting on the correct a/c pulley. If it stops raining I plan on going to pic-n-pull for a waterpump pulley. Its definetely going to be a "busy" set-up with all the idlers but its the only way as of now that I can get every accessory turning in the correct direction and have adequate belt coverage on the pulley's.
SSV
Here's a thought for ya & May eliminate an idler or 2 > palmer marine engines ran 'backwards' (so I understand) & therefore used a 'backwards' rotation wp too.
Remember justin (rip) on the 'old' bb? He got one (vane style) one time & couldn't understand why his temps (he had temp issues forever) went even higher than before. He pulled it (and pic'd it for us) & we all saw it was a reverse rotation wp. Ie; palmer marine engine wp.
Anyway: you wouldn't need a grooved pulley & could run the belt under the wp pulley & maybe eliminate 2 idlers in the process.
Just throwing out ideas for ya Jeff. :gringrin:
hth,
:cool:
ihpartsjeff
Staff member
here's a thought for ya & May eliminate an idler or 2 > palmer marine engines ran 'backwards' (so I understand) & therefore used a 'backwards' rotation wp too.
hth,
:cool:
I thought of reverse rotating the water pump but what other cooling issues will arise???? Cooling of the engine will be completely reversed. If I did reverse rotate the water pump I wouldn't even need a pulley as the belt could ride right on the pump itself. But to be safe I'll just keep things rotating the direction it was intended.
Dave Walters
I believe all reversing the pump will do is get water to the heads first, which will cool them better. Doubt the rest of the system cares. You May need to turn the t-stat around. I'll do a bit of asking. Got a couple guys up here pretty skookum on this sort of thing.
ihpartsjeff
Staff member
I really don't want to play around with reversing the water pump as these engines were not designed to be cooled this way. It also May not work right with the water pump housing. You would also have to change the fan blade as well. Thats too much too change in my opinion. I'd rather keep it simple so to speak by keeping every accessory turning in their proper direction with a simple bolt on kit.
X2. I have a lt-1. The cooling setup is very different than my gen1 sbc.
Keep up the good work!
ihpartsjeff
Staff member
I've been working on this a little here and there. I've got the whole configuration down to 2 idler pulleys and one auto tensioner. It would make it a lot easier to ditch the auto tensioner and use the alternator to tension the belt but I'm not done staring at the set-up. Ideally I would like the tensioner to be between the alternator and crankshaft as that is the end of the load so to speak.
ihpartsjeff
Staff member
Here's the final rendering of the serpentine set-up. The auto tensioner has been ditched in favor of a "jack-screw" setup which will keep more even tension on the belt.
Michael Mayben
Now I'm a "fan" of the serpentine drive ya got goin'! Ditchin' the slap-happy auto tensioner makes me feel a lot better!
A jack screw tensioner puts you in charge of belt tension, and not some crackhead engineering intern at GM!
ihpartsjeff
Staff member
Its not ready for market yet. We're getting ready to test the first set-up any day now. From there things will get rolling but no idea as to when kits will be available or pricing.
Allan E
I had to ditch the generator setup in my b120 to get it to fit inside the engine compartment when I switched to a 392. The stock 304 setup was tight, and the extra 3/4" made a difference. This setup looks to be much wider on both sides.
Will there be clearance issues in the Scout?
ihpartsjeff
Staff member
The serpentine belt system is no wider than a stock vbelt system except for the p/s pulley which is a little larger. More testing needs to be done in order to confirm that there will be no issues when installing the serpentine belt system in a stock Scout II.
Karl
Just dropping in to let you know of more interest for this kit. I'm rebuilding a 79 Scout terra w/ 345, and I'm looking forward to updating some of the tech in it. And being able to properly bolt everything down will be nice. I'm assuming there will be a non-ac variant? I can't wait to see the finished product! I'm glad I found you guys.
