Ignition Lock Cylinder - '79 Scout II
jxfinch
Hopefully this is a basic question - but i've seen differing answers. Hoping someone can set me straight. The ignition lock cylinder in my '79 Scout II w/Tilt Steering slides in an out freely. Still starts the vehicle, but doesn't stay in place. I've seen that some columns are held in by a set screw - others by a retaining tab. Anyone have any clue what I need to fix this? If its a screw - any sources? Went ahead and ordered another lock cylinder from IHPA anyways - but worried i'll end up with the same problem. Thanks!
You need to pull the wheel, the horn, the signal cam. There is a small spot that you drill and put a #8 or #10 pan head screw in to hold it in. Believe originally they were only press fit in.
