brad bedell
Hello, I need some help determining what would be the proper carb to use for my motor. I have an .020 overbore on a reletively stock rebuilt 392. It has a dui ignition, rpt square bore aluminum intake with an rv cam, and 2 into 1 out a 3" exhaust. I live at 5500 feet and rarely go below that altitude, usually higher, up to 11000. This is in a Scout 800 with an automatic 727. It has 32" tires with 3.55 gears (4.11ish in the future). Please keep in mind, with the 392 and a 3/4 phenolic spacer, my air cleaner to hood clearance is quite minimal... I really do not want an automatic choke as I have had horrible luck with them in the past! All help is sincerely appreciated! I am leaning towards the edelbrock as currently there is a carter on it, then I would have to change around fuel lines, kickdown etc...
Thank you,
brad
Thank you,
brad
