4" springs, 3" body, bumps stops, steering stop adjustment and maybe a minor fender trim at the edges will fit *most* 35's.
All easy bolt-ons that can be done incrementally.
I would only recommend longer shackles to make lift springs work better, and even then maybe 1-2" over stock.
In this case its not only a mater of the amount of lift (7" in this scenario), but also the limiting articulation of the stiffer lift springs that will allow you to fit 35's. A SOA will typically net you 6-7" of lift with stock springs, but you can make 33's or even smaller rub.
Find a deal on a set of used 4" lift springs (~$250). Buy new, quality shocks, new body bushing with your body lift, borgson or similar steering joint and enjoy your Scout.
