Holley 2300 Starting Troubles
77SSII
I have a '77 304 w/a 727. The 304 has a mild schneider cam (256-2h grind), bored 0.060" and the block & heads where shaved .100" w/some flat-top hyper-eutecktic(?) pistons, air injection ports plugged & ground and a set of stan's tri-y headers w/some mock-up cherry bombs just to get it running. I am using a new model 2300 (4412c) carb I bought in 2003 on a stock manifold and I put an electric choke kit on it. I am also using a dui unit that fits extremely tight although Jeff & Darren say it should fit pretty good:). Performance dist. Said I could remove 1 of the 4 hold down bars to get it to fit better so I ground the thermostat housing & water neck(?) and dremmeled the cap to give me maybe 30 degrees of rotation. Anyways, I've got it to the point where is starts almost immediately and idles around 500-600. It will run on it's own for anywhere between 15-50 seconds then just dies w/no sputtering. The engine runs smooth w/no vibration and all 8 header tubes are hot. If I gently step on the accelerator peddle, the motor will run up to 800-900 then die immediately. When it does, I immediately open the float bowl site screw and fuel gently trickles out as it is right at the base of the threads. I cleaned the 4 air meter thingys on the carb throat that look like little jets w/my paint gun cleaning brushes & laquer thinner.
I am running a kwik wire 14 circuit harness that has a 14 gauge wire feeding the "bat" terminal on the distributor. Performance dist. Says that is too small and I should be using at least a 12 if not 10 gauge. Because I can't re-wire the harness I am running a 10 gauge wire to the starter solenoid.
I tried the "r" stud and it won't catch now. I put the original 14 gauge back on and it starts. I then put the 10 gauge directly to the battery and it will start but the same thing happens, 800 rpm and dead.
I know you probably have to go home and shave again after reading this novel but what do you think?
Mark from boston
Got it!!!
It was the control module inside the dui unit...
Brand new, 6-year old unit with a bum module. I brought it to a local advance auto parts and they tested it. Bought a stock one and will call performance distributor Monday to see about a replacement.
Jeff said the 14 gauge wire should be fine to feed the distributor or I can use a relay and run a 10 gauge out of that relay to the distributor.
The truck fired up right away!
