Rebuilding my Holley 1904. I have a Spring vs a Weight in The Pump Discharge Valve within the Economizer Body.
Stack up from top to bottom:
Pump Discharge Valve Retainer Screw
Spring
Small spacer (flat on one side, concave on other)
Pump Discharge Ball
Questions
1 Should I replace spring with weight (did not get one with carb kit) would need to find weight?
2 Is the spring and spacer sufficient vs Spring?
3 Spacer between spring and ball, flat side upward in contact with spring and concave down in contact with ball? (No diagram in the 1904 manual I have.
Spring
Pump Discharge Ball
Questions
