Hi Steer
76 Patriot
I am working on a SOA on my 76 sii. I have a set of flat top knuckles from an IH 8-lug disk front end. 2 questions;
1. Can I use these knuckles with my 5-lug hubs and stuff?
2. The steering arm is only on one side. The other side is flat top, but it's not drilled for an arm, instead it has the forged arm. The forged arm only has one mounting hole for the drag link/tre. Will this work with the stock sii drag link and tie rod?
Thanks.
ihpartsjeff
Administrator & Owner
Staff member
These knuckles will work perfect. Send me your passenger side knuckle for machining and tapping of the hysteer arm. You will need a hysteer arm kit which I have several different kinds in stock. Best to call me and let me know your whole setup is so I can set you up with the proper arms.
76 Patriot
Jeff, sorry it's been so long on this. Everything has been uphill seems like.
Anyway, I finally got the SOA done and with Chad's input, was finally able to get the z draglink hooked up so I can drive it. Now for histeer.
I would like to send you both knuckles. The ps needs to be machined and I can't get the arm off the ds. Also, I would like to have the forged arms removed so they're not sticking out there (if this step is really expensive, I can do it myself).
I will need to run the spacers under the new arms. I will run the two hole ps arm (for dl & tr), and the single hole arm on the ds (for tr only). I will need the dl and tr with 1 ton ends. I guess that's it.
Please pm or email a quote at your earliest convenience, and let me know an estimated turn-around time. Thanks a lot.
Heith
ihpartsjeff
Staff member
Heith
Left you a phone message I think at your home address. If you can give me call about pricing and turn around time.
Thanks!
