dieselwalt
I have a diesel which I would like to resolve some starting issues.
I need some expert help, as I used to be able to get it started and now can not.
Last time I tried, the battery terminal turned bright red, so I stopped attempting it.
Previous means of starting involved a small shot of starting fluid..
Not sure if I need some fresh glow plugs or ??
Or even better someone who services these things in wisconsin...
1) vehicle model. - Scout II
2) production date/or year model. - 1980
3) two wheel drive or four wheel drive. - 4x4
4) type of transmission (and transfer case if applicable). Stick
5) if 4x4, which axles front and rear. - d44s
6) which engine variation. - sd33t
7) which ignition system variation.
8) which fuel system variation.
9) which brake system variation.
10) non-oem modifications present which May impact a response.
