I should have discussed this problem but it is just one of many. I did have the housing surfaced and it was not out of spec. Put it back on and still leaks out of the front top corner.. Am thinking maybe the front cover is the problem and the fan is moving it around the corner since the leak shows up at the same place. What do you think?
Most certainly could be blowing around the corner! Likely suspects...
1) front crank seal behind the crank hub, crank hub May need a speedee-sleeve.
2) pan gasket where it meets the timing cover. A seal/timing cover gasket set includes a short segment of the pan gasket to use to replace the part ya gotta remove when the timing cover is removed.
3) remove/clean/use a sealant on the four front pan bolts that thread into the timing cover rail. They are blind holes but one of 'em May have a void (casting blow hole) allowing oil to leak past the threads.
4) use sealant (like permatex #2) on each filter adapter mounting bolt to prevent oil wicking past the threads.
5) dipstick tube is tight in the block???
6) oil droolin' down from the front of the lifter chamber cover under the intake manifold.
7) oil leaking past the base of the distributor, I replace the oem gasket on distributors with an "o" ring.
Powerwash the front of the engine, especially from underneath. Then spray "powder"-type foot spray all over the suspect area. The oil leak points will be real obvious as they appear through the "flat" dry powder.
