Heat riser valve
Bill USN-1
F.I. Moderator
Since you won't have a mech choke pull off there is no need to have exhaust flowing thru the intake manifold.
That's the purpose of that flapper valve.
The ports are on the intake manifold.
If the manifold is off then you can also run the LPG intake gaskets.
But they are not required or needed.
Just don't run the flapper if it's bad.
For others reading,
No, this does not mean you need to remove yours to install EFI.
It just means that if the flapper goes bad or is creating an exhaust leak(bad for O2 sensor) then just remove it.
RustyBucket
For others reading,
Thanks for the info Bill.
dkminors
You can remove the flapper and weld in a couple of shortened bolts to cover the holes on the flapper housing. By leaving the housing in there you won't need to address any gap between the manifold and exhaust piping.
Bill USN-1
F.I. Moderator
I normally just tap the holes with a NPT tap and install pipe plugs if I leave it in.
Some times the cast will crack if you weld on it.
