headlight bucket needed and other parts
Hi,
-1- I need at least one complete headlight bucket for my 62 pickup truck.
-2- in addition I also need several headlight screw adjusters for the other bucket. Not sure what else to call them, so see the pictures below. Apparently they are or were available separately at one time. Four of the original red brittle ones have split where the adjusting screw threads in. And I have this other one that is white, a bit heavier and attached with screws rather than rivets and apparently used to replace a screw adjuster that split sometime in the past. If I can't find 4 of these headlight screw adjusters, then I am going to need two complete headlight bucket assemblies.
-3- also looking for the lens and/or lens gasket to the running lights/turn signal below the headlights but interested in the lens only if that lens is glass and not plastic.
-4- also looking for a non-dented headlight bezel that's reasonably priced.
Your help in finding these parts is appreciated.
Steve
http://forums.IHPartsAmerica.com/attachments/wanted-goods/24680d1399876587-headlight-bucket-needed-other-parts-may_11_14_pics-259.jpg[/img ]
[img]http://forums.IHPartsAmerica.com/attachments/wanted-goods/24681d1399876649-headlight-bucket-needed-other-parts-may_11_14_pics-273.jpg
Forget the plastic adjusters. I found them here. I don't know why I didn't check here before posting. :icon_redface: but still need everything else.
Steve
Hi,
I found the headlight bucket and bezels. But I'm still looking for the headlight/parking/turn signal connectors shown below. Are these 2-prong wire loom connectors available new or reproduced anywhere?
And/or is the headlight bucket grommet available anywhere? It uses a grommet made for a 1 1/8 inch hole. I found vintage Chevy ones for a 1 1/4 in. Hole, but would prefer not to ream out the hole, if possible.
http://forums.IHPartsAmerica.com/attachments/electrical-tech/24704d1400485098-headlights-may_18_14_pics-147.jpg[/img ]
thanks .
steve
