62international
Question,
ive got a 62 Scout, 152, 3 speed, 4x4 Holley 1904 carb and when im in 2wd high gear it dosnt wanna go while in first gear you gotta rev it up kinda high and then let off the clutch easy while it is reved up and it gots but if you just do the give a little gas take a little clutch thing it pops out of the carb bad and spits fuel up in tha air and tries to die. But, in 4 low and first gear you really dont even have to give it gas at all just let off the clutch and it goes. It kinda has alot of blowby coming out the oil filler neck too.
Im thinking maybe I should rebuild the carburator or maybe just adjust the air fuel mixture screw or something. On another note, I took it offroading the other day through some woods on 4 wheeler trails and it performed exalent.
