rangerslim
Got a couple questions with the bw11..mine is behind a 232 six and I bought this trans. From behind a v8. I replaced front and back seal and pulled the pan to take a look and it looks perfect, no metal or anything. But when I drive it, it does not go into second unless I manually shift it or tach it real high...will not shift into drive until I run it a couple miles, then it will shift fine from second to drive....just will not go from first to second....I noticed the modulator on this one looks nothing like the one that was on my original trans. That I pulled out.thanks
oh, it's a 71' 800B. And when I've driven it a couple miles it will shift out of first but it seems like it's missing second all together and trying to go into drive. This transmission doesn't slip whatsoever. And I haven't attached the wire on the side of it for the kickdown either, thanks.
