gfast2
Thank you.yes that is a transmission cooler.it was mounted therenice work. It's going to be so much nicer to work on from here on out with everything all cleaned up. In the next last pic there is something mounted under the floor on the left side outside the frame rail. Is that a cooler fan or ? That's a real vulnerable location.
just to get the Scout to the transmission shop.I was gonna rebuild it myself,but the transmission vendor my shop works offered me a too good to be true deal on the rebuild.well it was,it was leaking so bad you could'nt stay under it without getting a shower.so now that that is fixed I bent up new lines & installed every thing correctly.
