FatSmitty
I have a 79 Scout II that I recently bought, with 345, came stock with 4 speed manual tranny/po converted to tf 727 with d20 tc and has working ac with a saden comp. Also po had a IH only guage panel and isspro gauges installed by a garage(he gave me reciepts of work done). Here are my questions:
does the new panel/ gauges have a cvr?
Do the new gauges work with my stock sending units?
Here are my issues:
oil pressure goes from 0 to full peg over/100 when engine is running, sometimes at idle it will go from 0 to 100 back and forth.
Tach seems to work, but when I shut her off the tach needle stays at 800 rpm Mark.
Speedo doesn't work (this is a broken speedo cable)
temp gauge seems to work (starts out low and climbs as engine warms up)
clock works
ampmeter or voltmeter which ever it is, seems to work but is all over the place, e.I. Low when at idle climbs with engine rpm, at idle with blinker on tics back and forth a little.
Fuel gauge always shows at a hair under 3/4's full (have checked it topped off and after 90+ miles of driving with no change). I have a new (stock style from vendor)sending unit(19 gallon) to r&r, just wandering what else to varify/ check to get this working right.
Also the gauge back lighting and blinker indicator and high-beam indicator lights all work.
What are some ideas to start looking at to correct these issues?
Here is what I've done so far:
cleaned battery terminals and battery posts
grounded battery to engine block, block to frame, and body to frame.
Replaced all fuses in fuse block under dash
visually checked over bulk head connector
also when po converted from manual to auto tranny, I believe they hot wired the nss as she will start up in gear, I'd like to un rig this overide for safety's sake. And the back-up lights are inop(tranny wiring?)
I have a truck service manual for Scout II xlc series number cts-2310 shows for 1976-1977, will I need another manual to cover electrical changes for a 79?
Thanks for any and all replies/suggestions.
Nevada
Here are my issues:
clock works
Nevada
