orng blsm spcl
Hey you guys I have a chance to get some k5 blazer full width danna 44 front an 12 bolt rear for next to nothing almost free. I'm torn between that an my 44 Scout sprung over axles I have in it. I like the full width because I can get off camber better an not be as top heavy but then I cant get threw such narrow trails which I can easily do with my Scout 44s. An parts for the k5 axles are everywhere an easer to get then the Scout axle.plus I can put bigger tires on the full widths an not rub on my inner finder but ill still have to cut the out body for the tires, but with Scout axle if I go bigger tires then ill rub on my inner body finders an still will need to cut my out body an finders for bigger tires. You see!!!! I'm torn in between the two
