fuel pump needed
scout man
I need a fuel pump for my 65 Scout 80. I just need a peice off of it so if it in need of seals it is ok. I just need the very bottom porshion that the sediment bowl sits on.
I assume it was working the po drove it home then it sat for years. It was part of a package deal. I trailered it home took off what I needed and there it sits.
Oh I wont be traveling quite that far north so could you please post some pictures. And if the rear passener corner panel is not badly damaged I May also be interested in that.
Pictures of pump.,, and the corners panels have been welded to the side panels
Again sorry for the delay, but the arm on my pump has the little sliding piece that the cam rides in, do you know if not having that would make a difference? I dont think it would. Im going out of town tomorow as well so itll be probly a week and a half un til I can talk to you again. Thanks for being patient!
The speedo works when hooked up to a drill,the other im not sure I have never had the rig running to see.so I would do 50.00 on speedo and 40 on the other +shipping.
