Jeff,
do you guys sell any of the components of the kits separate or remove any thing from some of the kits someone might not need.
Ie sensors? I've aquired most of the pieces except the adapter, fuel pump and depending on what I do to my distributor. But I was debating on buying the diy kit to avoid having to mess with the wiring mess of the junkyard harness. But if I can figure out the wiring harness out on the patrol I am going out on I wouldn't need it would that reduce any of the cost of the kit?
Now the distributor options I have in front of me are
1. Bite the bullet and either run the dui with the filter or modify it properly and hope it all runs by the end of the weekend. (dd need for work)
2. Buy the custom distributor from you in which case how much?
3. Go and aquire a remanufactured or go used gold box or points distributor and modify in accordance to bill's instructions or find one someone already did lol.
4. (this is a dream option here) send the dang thing or any one of my trucks laying around to you and receive it months later built to the teeth sigh where is that winning powerball ticket?
Thanks again for the great products though... I will be buying something in August no matter what...
Rich
Rich
