Fuel Injection High Idle in Hot Weather
Hi,
What can cause high idle in hot weather?
I have Affordable Fuel Injection sold here before Hamilton FI; IH 345/auto and aluminum intake and stan's headers. Recommended Robert Shaw thermostat, can't remember the thermostat opening temp.
Just made my annual trip to Colorado for 4 wheeling:)
No problem on the whole trip UNTIL driving home across Nebraska and Iowa it was in the high 90s all the way. Highway cruising at 70 MPH and every time I stopped the idle was screaming at 1500 RPM. I had to stand on the brake just to hold the truck still!
Popped the hood to check throttle linkage; all good and tight to idle set screw, so definitely IAC/PCM kicking the idle.
No engine light unless I leave it idle high for several minutes, then I get a check engine light.
When I shut off the truck and restart, no high idle and no check engine light. Runs absolutely fine. Restart fixes the high idle without waiting for the truck to cool. High idle returns after every long highway drive in hot weather.
I have the stock dash temperature gauge; never gets above halfway whatever that means:unsure: Plenty of coolant, no indication engine is hot.
The fuel injection does have have a temperature sensor. Does the fuel injection think the engine is hot and kick the idle?
No AC; driving that heat was pretty miserable:(
