IHCScout78
Looking at the 5 inch front shackles and the recommended 4* caster shims.
Can this setup be used with stock front drive-shaft and 2" Skyjacker springs?
Current suspension set-up: 2" Skyjacker both ends; stock shackles front, 5 inch rear. Caster is -3, frame angle is 1*. 32-1150r15 mtr tires. No current issue with drive-shaft.
I jacked her up and looked at the front drive-shaft yokes with the suspension hanging. There is very little clearance at the t case yoke now.
I hoped to use the 5" front shackle to level the frame and the 6* caster shim to get to 0 or possibly +1* caster, but now I suspect this will be trouble. I'd appreciate input from any one who has tried something similar.
Btw the little extra height in the rear + 2" body lift and raised bumper has really minimized the tail dragging off road, but I was surprised how often the rear 5 inch shackles hit rocks. The shackles hang below a line from the bumper to the tire contact patch, leaving them pretty exposed.
