pineneedle
O.k. I assembled the two pieces of the passenger side axle shaft. It was a bear to get the c clips into their slots on the u-joint. Now the joint is stiff (no pun intended). I tried the old mechanic's trick of striking the yoke with a bfh to relieve the stresses, but it is still stiff. So, can I let it go and figure that it will loosen up with use, or do I have to take it apart and mess around with it some more. Just so nobody has to ask, "how stiff is it?" I can move the shaft up and down with a little effort, but it will not drop of its own weight.
Pineneedle
Pineneedle
