flare to O-ring adapter? and pump question.
I messed the steering gear up in my 1980 Scout, I have an o-ring pump and o-ring hydrobooster on it, so I do not want to flare one end of the line to adapt to another box, here's the issue, I have a good flare style box. I know there's press in fittings to go from o-ring to flared, is there an adapter to go the other way?? :confused5:
also I want to "boost" my pump to help turn the 37's, there used to be a full write up on how to do it, but I can't find it now. Anyone know where it is?
Thanks!
-jon
Summit racing or jegs. I went all an fittings and never looked back. Fwiw you need steel power steering fittings as the pressure is to much for aluminum on the high side of the pump.
