I guess I should relate my recent experience with the driver's side exhaust manifold.
I have always had "problems" in this area over the years -- including replacing the driver's side exhaust donut twice on the side of dirt roads in the desert.
In "preparation" for last weekend's trip to death valley, I decided to be "proactive" and have the driver's side exhaust donut replaced.
Well, that lead to "more problems" -- it turned out that there was a crack in the flange of the exhaust manifold which eventually broke resulting in replacing the manifold.
As part of the attempt to "seal" the connection (before the manifold broke), the muffler guy replaced the "donut downpipe" with a "down pipe" with a flat flange - requiring a flat gasket instead of the donut. (he did not "like" the donut.)
I got a new manifold - the muffler guy said I should get a new manifold instead of used because of the long term "effect" of heat on cast iron. He also said that the pass side exhaust manifold was showing signs of such deterioration -- "light gray areas" on the manifold.
I put the new manifold on and hooked up the new down pipe "successfully" -- no noise / exhaust leaks.
I noticed a slight increase in the "torque" / "pickup" getting on the freeway as I drove my t/a back to the muffler shop for him to check out.
The inside of the old exhaust donut was slightly "eroded" from not being perfectly aligned with the exhaust manifold.
On the trip down to death valley, I was able to "pull" the north ("steep") side of tehachapi pass (CA 58 bakersfield to mojave) all the way in overdrive. In recent years, I have had to use 4th up this pass on the "steeper" parts.
So, I assume that the slightly misaligned exhaust pipe was the cause of slightly less power. I just thought the motor was just getting old (like me
Not a recommendation to replace the donut with a flange -- just need to make sure the exhaust system is "correctly aligned".
I do not know if this is an issue with scouts -- or other fullsize ihs -- just might be my vehicle.
Hth
Hth
