JAYSON
74 100 345 @1400rpm + - 100 rpm the eng. Vibrates like a almond shaker! It started after I pulled and reinstalled the 345 I noe I forgot to index the pressure plate to flywheel but I belive the clutch should be neutral right and the flywheel has a locating pin ? I did a hermonic balancer swap no luck so im thinking its on the other end btw not drivetrain related does it in neutral clutch in or out and ingear while driving ill try to get vid
