Engine Comparison ?
nintengu
Is there a diffrence between a 1970 Scout 800a 304 vs a 1772 Scout 2 345 ? If the only diffrence is piston or internal diffrence would I be able to bolt a power steering pump using a scout2 bracket?
The primary external difference between a 304 and 345 is that the 345 has a 1/2" taller deck height to allow for the longer stroke. The external brackets should all exchange.
