If Chad or Jeff can put up a pic of the lincoln fan system, along with external dimensions of the shroud and mount points, I'll see if I can cross that over to a dorman aftermarket unit which would be available new for much less cost than from a dealer.
That lincoln system that I've seen on Chad's app is the only viable electric fan system I would consider using for my own stuff, that's based on it being the proper size, the shroud design, and air flow volume. It's a great matchup for the sii radiator/core support footprint.
