ECM fuse keeps popping
jchazen
Why would my ECM fuse blow? I mean I understand there must be a short but not sure where to start looking lol..any help would be appropriated
Bill USN-1
F.I. Moderator
Are there any error codes?
Have you checked the pins on the back of the ECM?
Bent, dirty?
If you swapped the chip recently, are there any bent pins on it?
Harness chaffing?
You can send me the ECM to test.
jchazen
Trying to track down a laptop with a cd-rom drive so I can check codes...I might have to sent it to you..unless I can take the ECM to Jeff and he can check it?
ihpartsjeff
Administrator & Owner
Staff member
Feel free to bring the whole Scout by josh so that we can double check our installation and make sure a wire hasn't rubbed thru. We can also check for codes at the same time. Please call me ahead of time to make an appointment when you would like to bring in the Scout.
Bill USN-1
F.I. Moderator
You don't need a laptop for codes.
Just put a wire or paper clip in pins a and b of the diagnostic connector and then turn the key on.
The light will blink.
Count the blinks and look up in the manuals provided with the kit.
Right now without the jumper, the light should come on when you turn the key on and then go off as soon as you start the engine.
jchazen
tracking says it will be there tomorrow.
Looked up your order, it was May of 2014.
Yeah it was originally for my 75 with a 304 never installed...bought a 73 with a 345 from Jeff gave him the unopened box and they installed it last May...thanks again
josh
ihpartsjeff
Staff member
yeah it was originally for my 75 with a 304 never installed...bought a 73 with a 345 from Jeff gave him the unopened box and they installed it last May...thanks again
josh
And I can vouch for that. Kit was brand new in the box. Not sure if you remember bill but I had you burn us a new chip to work with the 345 and I think swap us out on the TBI adapter.
