Before I get to my question I’d like to say thank you to all who contribute to the forum. This site has been a wealth of IH knowledge and assistance.
My truck: ’73 Scout II 4x4, 345, 727 auto, Dana 20 transfer case, drum brake Dana 30 front, drum brake Dana 44 rear. No brake booster.
Problem: my brakes get very tight (hard pedal) after about 6 miles of driving. With foot off the brake pedal the resistance is enough to prevent rolling at idle but not enough to stop the truck. It's like I'm driving with my left foot resting on the pedal. When in this condition there is zero play in the pedal, it's tight in the up position and hard to press. If I park the truck for 30 minutes everything returns to normal, no undue resistance felt and the truck rolls freely in neutral. At no time is it difficult to stop. The problem seems to be too much tension but only after driving a bit.
History: my Scout had been sitting for years while I was living overseas. I went through all systems a few months ago and replaced several components. Drums were replaced up front and resurfaced in the rear. New brake cylinders and linings were installed at all four wheels and tension was adjusted. Fluid was changed and flushed though all lines- no air in system. At this point the brakes worked correctly. After a couple months of driving the master cylinder began leaking so I installed a reman from the local parts store. At this point the brakes seemed quite good considering they are unassisted drum brakes but after driving a bit (6-10 miles) the tightening problem occurred.
Thoughts: is this a bad master cylinder that is building pressure but not releasing it? Could the adjusters at the wheels be too tight and need more play because the master cylindar is new? I read where some vw guys had similar issues caused by heat/friction but don't know if that theory fits here. Any thoughts, experiences or suggested testing measures would be appreciated.
Thanks to all.
Geach
Thanks to all.
Geach
