Draft Tube vs. PCV Valve
Unknown800
Hello-
Looking for opinions on crank ventilation. I am in the process of building up my 800 (152, T18, D20) and believe I have enough parts to do either method of crank ventilation. My restoration is not a "line set" restoration....more of a resto mod as I don't know the year or original equipment for my Scout.
Is there an advantage to the pcv valve vs. the draft tube? Will the vehicle run the same with either set up? Is one more "Scout" true than the other?
Thanks in advance!
According to the factory parts catalog MT-113, the change from draft tube to positive valve occurred during the Scout 80 model run with chassis number FC 63573. So from a "period correct" standpoint, your later 800 model would be well into the PCV style. I don't know all the science or precise vernacular to properly explain the pros and cons of one system versus the other. I just know the general consensus and modus operandi has long concluded that the road draft system made for dirtier conditions both inside and outside of the engine.
FDChappie
Active member
If it were my engine PCV Valve. There is no possibility of dirty air in the crankcase with a PCV and no stinky fumes from the road tube.
