Albuq. Henry
1970 Scout 800 with a 304.
When I got this rig it was set up with a Holley points firing a heathkit cd box.
On Friday I swapped out my points Holley for a Holley gold box setup from my '76 parts Scout. (sv-345). Now that I swapped for the 345 dist., while setting it up, when I first revved it, it advanced a few degrees and it stayed there. I ended up taking the dist out and looking at it.
Not sure what correct name of the part is but the part with the reluctor that "stabbs" into the weights with the forks, there is play between the weights and the forks. After looking at another dist. It looks like I am missing some bushings??
Another thing I saw when I first set the timing was timing Mark wonder. Turns out I had quiet a bit of play up and down on the shaft with the gear. I removed the gear and put a brass shim between the gear and the housing. I know you have talked about removing the the play on the shaft but is this a "correct" way to do it?
Right now it is running very nice. Nice steady constant spark. However no vac advance.
I would like to build either the points or gold box dist and set it up to fire an msd type box with a pertronix or similar.
Are these repairs something someone can do at home?
