SSMinnow
Installing a disk brake conversion I bought from you and I have a couple of questions.
First, on the clocking the brake caliper is this ok or should I move it down/more towards 3?
Second, I cannot get the loaded caliper on the disk, not enough space between the pads. Is the piston already bottomed out? I tried using a c-clamp, but did not want to force it, or is it threaded and needs to be rotated back?
Third, underneath the inboard pad was a spring, dang thing fell out. I am assumming its for antirattle or something. The open end is suppose to be toward the axle or outboard?
Hope these make sense, thanks.
