Diesel Traveler questions
xyz12383318
When we talked yesterday you said it might be a good idea to post some stuff about my build as well as some pictures so you could give me some feedback. Well, here is my Scout, a 78 traveler that originally had a sd33. I have replaced the sd33 with a 4bt, nv4500, and NP205. I had it running and then pulled it down for paint etc... You can see from the pics I put in an IH only reverse shackle. I also cut down a Chevy front axle and put the stock Scout axles back in. I rebuilt both the fron and rear axles and rear axles using all new clutches, seals etc... And I put on new brakes all around. Soon I am going to start to put back on my panels and get the body work and paint finished. Please excuse the dust all over the Scout it is a project that gets a few hours a week and has been under construction for a couple of years now. Here is how it sits.
Jeff,
here is the front axle
The shock mount. Is it too high?
Here is the other side
