Did Shift kit, now only have forward gears NEED HELP!
wolfman65
Hello all, first a little background on my rig. It is a 1975 Scout 2 with a 392 non I/c, 727 and divorced np 205 out of a travel all. The transmission and transfer case were supposedly "beefed up" in 2006. And it also has Dana 60s. Now on to my problem. I decided to do a B&M transpak shift kit on my Scout. I followed the directions correctly (I think) and put it all back together and now I basically only have first gear. It has a B&M ratchet shifter. I added 10 qts of B&M trick shift. However, since I apparently wasn't in neutral(the wheels were chocked) this May have been too much fluid. But I am running an auxiliary cooler in addition to running it through my radiator cooler. If anyone has experienced this before and knows what May be wrong, or some things I can look at I would appreciate it. I am stumped.
-thanks
