kyleandhisIH
Well I guess I figured it was time to make a new thread about my recent experiences with my own binder. The 304 still starts and runs well, nothing terribly erratic going on, no causes for immediate alarm. Still yet, I have no idea what to think about my "timing issue." to rehash, my motor seems to run best when the indicator reads 20 > 25 deg, on a light with no dial-back setting. Btdc. I have re-stabbed per the instructions handed to me in several places on this forum, and still I end up "chasing" the 20>25 degree point around, because that's just where it runs best. Three times now, I have used a long-shaft screwdriver to verify top dead center. Each time, I do my best to install the wires in a way that #8 is right in line with the rotor. From this point, I usually get it running ragged (which ends up being anywhere from 0 > 10deg) and then I play with timing until it becomes smooth and runs with nearly zero hiccups. Put the light back on, and guess what? I'm anywhere from 20 to 30 degrees registered on the light, so I'm convinced something just isn't right.
One of these "issues" May very well be this amateur mechanic. I can't say I've ever heard detonation, the only pings I recall come from dropped bolts hitting the exhaust, and the only knocking I've heard was due to the double-hump sump starvation issue. I have tried to advance the ignition to the point that it detonates while driving around in a rather obnoxious stomp-on-it manner. So far, I don't think this motor knows how to detonate. I have a very slight exhaust leak, which hinders my ability to hear when the motor is idling at its easiest. I don't currently have the tools to chop and fix the "professional" exhaust job that broke my flange gasket and prevented correct installation of another, so I'm living with a slight ticking noise of escaping pulses. Still yet, there's no way such a tiny exhaust leak could cover up a solid pinging, is there? I don't even notice the leak at cruise speed, and no irregular or scary sounds can be had during any kind of driving.
I got a little worried that maybe I was just missing the knock, so I backed off my timing until the point where the motor started to sound rough and show wider "pulsing" on vacuum sourced from the #8 runner (brake booster fitting), and this pulsating has nothing to do with the booster... It's just the motor itself. So I try to "time" it to where the pulsating is most consistent and less erratic & jumpy. Right now it sits at around 15 degrees advance, And tip-in makes this thing feel like a turd, no matter how many hours I spend setting and re-setting idle mixture and verifying good, strong accel pump shot. It wants more timing, it drives better with more timing, but I'm inexperienced and a little afraid of losing what is still the most valuable thing I can claim to own.
The idle speed also tends to wander. What I mean is that if I release my manual choke a minute into warm-up, it will idle at ~600rpm. After fully hot, it will idle at roughly 750. Based on advice from this place, I simply lean the idle mixture (after everything gets nice and hot) 45 degrees at a time until speed begins to drop, and then I back up (enrich) 45 degrees for safety's sake. I still have the egr installed, and verified functional/not sticking. I don't rightly know if I still have vacuum going to it, but I definitely eliminated anything else coming from the vacuum tree on my manifold. I check the egr just about every time to make sure it's not playing with my head, but every time it responds with a sickly change in idle quality, which disappears when I release the diaphragm.
I know that my binder-driving habits (maybe a few times a month) are not enough to damage this vehicle and I doubt I've caused any serious harm. I still can't help but worry that I am leaving it in an improper tune. I have spent too many hot summer days leaning over a hot engine bay, trying the same things over and over, and getting the same results. Once I think I've verified proper ignition setpoint, I try to verify that the carburetor is idling and responding in the way I'd like. But then, no matter what kind of fiddling I do afterwards, the vehicle acts like it's not in proper tune. I realize 3.56 gears are going to dog the hell out of even a fluid-linked powerplant, but I just expect more than coughing and sputtering like the stereotypical antiquated vehicle.
Tomorrow I plan on once again checking firing order (which is a number sequence I'll never forget) as well as the relationship between tdc and the odd numbers I'm receiving from the timing light. I hate to basically post a lot of the same info I've already shared with this forum, but I don't know what else to do. I don't have connections, and I surely know nobody who has dealt with this stuff before.
Thanks in advance.
Thanks in advance.
