BinderWalker
Hello fellow Bindernauts, I've got a 68 1200C 4x4 with (I think) a Dana 44 front axle setup. I just sent out for a build sheet so this is just a guess.
The truck is a complete frame-off restoration in-process, and many parts are needed. The first on my shopping list are the splined bronze bushings that sit atop the trunnion opposite the small tapered roller bearing on the bottom of the steering knuckle. I have found the bearings. Does anyone know please where these bronze bushings could be found? They also look "offset" meaing that they could possibly be used for setting the camber / caster?
I threw in a couple of pictures to hopefully answer some questions.
Any assistance on this would greatly be appreciated - thank you.
