Dana 44s (Geared, Locked, Ready to run)
Mochamike
These will be available in around the end of March/early April.
I'm moving up to d60s.
If you have a Scout 80 with 2.5" springs, these will bolt in easily.
(if you have narrow springs, they will work, but you'll need to make a spacer on your springs).
They're in bolt in & go condition.
74-79 Jeep wagoneer Dana 44s (6 lug)
front (passenger side drop):
SOA (for 2.5" springs), 4.88s, full detroit locker, hd diff cover (1/4" plate welded up on the bottom half), hi-steer, with 1.5" dom tie-rod & drag-link, 3/4 ton Chevy tres (I'm keeping the tre @ pitman arm), hd spicer u-joints, warn premium locking hubs, u-bolts & spring plates.
Rear (slight passenger offset):
SOA(for 2.5" springs) , 4.88s, Yukon full spool, hd diff cover (1/4" plate welded up on the bottom half), disc brakes (1/2 ton Chevy front rotors), will have fresh inner axle seals, u-bolts & spring plates.
Hd spring perches are 32" wide (spring bolt hole to hole) made of 1/4" or 3/16 (have to check) by 6".
Come with the following spares:
l & r front inners & outers (w/joints)
l & r rear shafts
4.88 spicer r&p (used)
spare warn locking hub (premium/used)
hub (1)
rotors (2)
spare pinion yoke
spare spindle
bag full of used joints
bag of lug nuts
I'm sure I'll find more misc parts when I clean out my parts cabinet/shed.
Price is $1500 for everything.
Package deal, I don't want to seperate.
Pix will be up in a few weeks once I pull the front.
Located in concord, CA
preference given to local pick up.
May travel in the ba to meet someone.
Will pallet/ship for some extra $$$ (you arrange pick up or local drop off).
