If its a sii d30 under there right now, you'll need the knuckles as well, or you'll have to re-drill the d30/drum knuckles (in this instance better to just swap knuckles).
I have a set of everything but the hubs and rotors. Might have a set of "good used" rotors as well, have to check. So basically everything but the wheel hubs (you can re-use the d30 locking hubs and you'll have to use the d30 stub shaft). They are even all cleaned and painted. Let me see if I can find were I stuffed them and we'll see if we can work out a price if your interested.
