Desertratsocal
I have a 1972 Scout II with a big block Chevy 396, turbo 350 and novak adapter Dana 20. I am running Dana 44's front and rear with disc brakes all around. The bbc is fired by an hei system and fed by a 770 Holley carb. The exhaust is novak block huggers designed for a Jeep application. The motor mounts are novak Jeep mounts for a older commander. When I adapted the transfer case, I went from a (tf 727) 18/8/56 bull gear to a 18/8/55 6 spline bull gear (Jeep t150). Also, the engine and transmission is offset by 1 1/2" to the driver's side for front driveline clearance for the turbo 350 pan.
Now the issue: when driving the Scout at highway speeds, I get a distinct whine/howl at starting at 45 mph on light acceleration. It doesn't do it on hard acceleration. When I back off the pedal, I get moderate gear noise which goes away as the speed decreases at around 40 to 35 mph. It does it as well during even throttle at 50 to 55 mph, but won't do it at lower speeds.
I have new drivelines. The transfer case functions properly and is full of 85/120 lucas gear lube. Both front and rear differentials have been rebuilt. The transmission and engine have been rebuilt. I have tried two different Dana 20's and they both did the same thing. I am running a twin stick on the transfer case.
The only thing I can think of is that the bull gear isn't torqued to the 150 ft. Lbs.? Would that cause the issue I am describing? Or does my Dana 20 need rebuilt?
Thanks!
Scott - usmc(ret.)
Thanks!
Scott - usmc(ret.)
