int77345
Active member
does any one have an idea how strong a dana 20 is ? and how it would hold up to the 3.15 low gear set. seems low gears would put more pressure on the t case. would it break out put shafts? gears? crack in half? or is it plenty strong enough to hold up to the scout 345 and 33 inch tires ???
thank you for any ideas or experience with the low gear set
