BANoriega
I have a 1975 Scout with a dodge 360 the Dana 20 and 727. My big question is what is the correct style of speedometer gear that I need and where can I get it. I can find speedometer gears for the 727 easy but I would just assume run the speedometer for the transfer case so I can have accurate speed while in 4x4. I will not be running the stock tire size I plan on running a 35" tire, and with the 3.56 axle ratio I will need a 27 tooth gear but now what?? Is changing out the gear as simple as unbolting the threaded portion on the the transfer case and pulling out the gear?? Please if anyone has any comment or information I would greatly appreciate it.
