smithflyfisher
I posted this in the binder planet tech talk forum, but I thought the more info I get the better, so here goes.
Just got done swapping my d30/d44 setup to d44s all around. I changed lines, mc, prop valve, and installed new brake hardware. However, my front discs (which are manual), tighten up and reaalllly drag me down after driving for about a mile and will not release. I can depress the brake pedal and release the pressure by bleeding the fronts, then they operate correctly until I get out on the road. I can't understand it, the brakes work perfectly for awhile, and then the pedal gets tighter and tighter until I can barely depress it at all, and I have to really get after it in 1st gear just to get rolling.
I used the front and rear axles from a 1976 sii and the prop valve from a 1974 sii. The prop valve was from a Scout with power brakes. I'm really scratching my head on this one...... It took me and my buddy the whole weekend to swap the axles. Any help would be greatly appreciated!!!
1972 sii, 304 3spd, 4" SUA extended
rear shackles, custom front winch bumper
